hasse skrev:Tænding på 10??
Tænding på 10! yes
Bent skrev:Er der blevet rørt ved tomgangsskuen ?
Er gasspjældføleren blevet sat tilbage på det samme sted?
Viggoman skrev:Bent skrev:Er der blevet rørt ved tomgangsskuen ?
Tomgang er justeret forskiftsmæssigt med kortslutning af gnd+ten.
Gasspjældsføler, du tænker at ECU'en ikke får besked om at gasspældet er lukket?
Har en co måler, men den måler ppm og ikke co%vol, er ikke helt klar over hvormange ppm der går på 0,49%
Kuksi skrev:Har en co måler, men den måler ppm og ikke co%vol, er ikke helt klar over hvormange ppm der går på 0,49%
0,49% svarer til 4900ppm
Du flytter bare kommaet 4 pladser, så kan du selv se logikken.
Concentration Symptoms
35 ppm (0.0035%) Headache and dizziness within six to eight hours of constant exposure
100 ppm (0.01%) Slight headache in two to three hours
200 ppm (0.02%) Slight headache within two to three hours; loss of judgment
400 ppm (0.04%) Frontal headache within one to two hours
800 ppm (0.08%) Dizziness, nausea, and convulsions within 45 min; insensible within 2 hours
1,600 ppm (0.16%) Headache, tachycardia, dizziness, and nausea within 20 min; death in less than 2 hours
3,200 ppm (0.32%) Headache, dizziness and nausea in five to ten minutes. Death within 30 minutes.
6,400 ppm (0.64%) Headache and dizziness in one to two minutes. Convulsions, respiratory arrest, and death in less than 20 minutes.
12,800 ppm (1.28%) Unconsciousness after 2-3 breaths. Death in less than three minutes.
Sakset fra Wiki.\"Parts-per\" notation
Main article: Parts-per notation
The parts-per notation is used in some areas of science and engineering because it does not require conversion from weights or volumes to more chemically relevant units such as normality or molarity. It describes the amount of one substance in another, and is thus related to the mass fraction. It is the ratio of the amount of the substance of interest to the amount of that substance plus the amount of the substance it is in.
Parts per hundred (denoted by '%' [the per cent symbol], and very rarely 'pph') - denotes the amount of a given substance in a total amount of 100 regardless of the units of measure as long as they are the same. e.g. 1 gram per 100 gram. 1 part in 102.
Parts per thousand (denoted by '‰' [the per mille symbol], and occasionally 'ppt', but this usage can be confusing because it more often denotes parts per trillion) denotes the amount of a given substance in a total amount of 1000 regardless of the units of measure as long as they are the same. e.g. 1 milligram per gram, or 1 gram per kilogram. 1 part in 103.
Parts per million ('ppm') denotes the amount of a given substance in a total amount of 1,000,000 regardless of the units of measure used as long as they are the same. e.g. 1 milligram per kilogram. 1 part in 106.
Parts per billion ('ppb') denotes the amount of a given substance in a total amount of 1,000,000,000 regardless of the units of measure as long as they are the same. e.g. 1 milligram per tonne. 1 part in 109.
Parts per trillion ('ppt') denotes the amount of a given substance in a total amount of 1,000,000,000,000 regardless of the units of measure as long as they are the same. e.g. 1 milligram per kilotonne. 1 part in 1012.
Parts per quadrillion ('ppq') denotes the amount of a given substance in a total amount of 1,000,000,000,000,000 regardless of the units of measure as long as they are the same. e.g. 1 milligram per megatonne. 1 part in 1015.
Er der nogen, der kan slå den?????
