Jeg er ved at finde ud af hvilken løsning jeg skal have på min NB-FL 2004 Sport med Koni coilover. Det jeg troede var en ret nem beslutning gøres ikke nemmere af at eksperterne er uenige Overvejelserne går på Racing Beat (og der er flere muligheder), Jacson Racing eller FlyinMiata. Dette indlæg ment som underholdning, ikke som et behov for flere gode råd, MEDMINDRE DU HAR EN NB-FL OG HAR ERFARINGER MED NY KRÆNGNINGSSTABILISATOR
Spring Rate for Koni'erne er foran: 103,72Lb/in eller 1,85kg/mm og bagi 89,9Lb/in eller 1,61kg/mm ifølge IL Motorsport.
Well, you should plan bracing the sway bar mounts regardless of brand choice. The sway bar mounts will break with any upgraded sways.
The 1.125 bar is a fine choice.
Brian Goodwin
Good-Win Racing
We only use the brace hardware, not the brace. Bushings included.
Your assumptions on bar diameter are incorrect assuming the correct spring rates. Not knowing what spring rates you have, I have no idea what sway bars
to recommend. It is impossible to make any calculation on sway bar rates without knowing spring rates. Good luck
Emilio Cervantes
www.949Racing.com
I agree that you would love our sway bars. If this is a street car you'd be fine with the stock end links. Let me know what you'd like to do, Thanks
www.flyinmiata.com/V8/
Jeremy Ferber
