SPS Motorsport
Re: SPS Motorsport
Indlægaf GuidoSPS » tors 26. mar 2020 11:38
Hey guys,
we have a special offer for You.
We sell our TD04-Turbokit for the MX-5/Miata NA, NB and NBFL for just 3499€.
On the stock 1.6L You get 220hp at the flywheel, on the stock 1.8L You get 250hp at the flywheel.
The kit contains:
Kraken cast iron manifold
Two-piece downpipe (first part made of cast iron, second part made of stainless steel)
Turbocharger incl. Matching connection accessories
Steelflex oil feed pipe
water pipe
High temperature oil return
Giselwerks Hardpipe boost pressure piping
efficient intercooler
Open air filter
SPS Motorsport 700CC Injectors (calibrated and tested)
Engine control unit with matching basemap
mounting material (incl. spark plugs BKR7EIX and modified washer fluid reservoir)
https://www.youtube.com/watch?v=v18XYMgpjmU&t=0s
https://sps-motorsportshop.com/shop/en/detail/index/sArticle/1834?number=TKIT-NA-16-TD-04-SLLK-MMS38998-SPECIAL
Best regards
Guido from SPS
GuidoSPS
Tilmeldt: ons 24. apr 2019 07:26
Re: SPS Motorsport
Indlægaf GuidoSPS » tirs 7. apr 2020 08:50
Hey guys,
just in case You didn't know. We make a sale for Japan Racing rims.
So every Japan Racing rim is 20% cheaper.
https://www.facebook.com/SPSMotorsport/ ... 929374217/
https://sps-motorsportshop.com/shop/en/ ... acing/?p=1
Best regards
Guido from SPS
GuidoSPS
Re: SPS Motorsport
Indlægaf GuidoSPS » ons 29. apr 2020 08:15
One of our bigger projects this year:
This MX-5 ND G184 gets a full engine swap to a 3.7L V6 LFX Camaro engine with transmission. And we use the car to develop a safety rollbar for the MX-5 ND, also to attache 4-point-harnesses.
Best regards
Guido from SPS
GuidoSPS
Re: SPS Motorsport
Indlægaf GuidoSPS » tors 14. maj 2020 07:52
Hey guys,
here we have e really clean an nice looking NA with a Borg Warner EFR6258 turbo conversion on a stock 1.8L BP making 250hp. Also a very cool detail, the 7x14" Enkei RPF1 with 185/60 R14 Nankang NS-2R.
Specs:
- 1.8L BP with EFR6258
- ME221 ECU
- 3" exhaust system
- Enkei RPF1 7x14" 28mm offset with Nankang NS-2R 185/60 R14.
- Xtreme Clutch Stage 1
- BC Racing BR Series coilover setup
- Mishimoto performance radiator
- Sparco Sanremo steering wheel
Best regards
Guido from SPS
GuidoSPS
Re: SPS Motorsport
Indlægaf GuidoSPS » lør 16. maj 2020 08:10
This is a really nice equipped MX-5 NC 2.0L. The car got some Recaro Pole Position mounted on our new developed seat brackets in combination with our new roll bar for the MX-5 NC and a 4-point harness. The car also got our SPS coilover setup, H&R anti-roll-bars, 17" OZ Ultraleggeras with Nankang NS-2R, a CarbonMiata Ducktail and a CAE Ultra Shifter.
Best regards
Guido from SPS
GuidoSPS
Re: SPS Motorsport
Indlægaf GuidoSPS » fre 24. jul 2020 10:06
Hey folks,
the last post was a few weeks ago. Now I have something new for You.
As You may know not only our customers drive MX-5s/Miatas, also some of our employees have them.
This is the car from our professional for all body work. It got a full Carbonmiata widebody kit which he installed by himself. The car also has a TD04 turbo conversion on its 1.8L BP making 250hp at the flywheel. To get the wheels (10,5x15 -13mm offset) fitted under the fenders he also installed camber arms on the rear axle together with our own SPS Super Low coilover setup. In the interior he installed a pair of Bride Low Maxx seats.
Best regards
Guido from SPS
GuidoSPS
