Vinterkuller (for det kan ikke være forårsditto....endnu).
Men det kan jo være svært,når den ene tråd starter med \"Snart forår...\" og den anden med \"Endeligt forår....\"
1: This battery is very different to the normal ‘wet cell’ battery. From a charge/discharge
view, you need to think of it a bit like an onion with many layers! When in use, the charge
is taken from the centre of the battery, working outwards. When re-charging, the charge
starts at the outside and works in. It is for this reason that, should the battery become
discharged, you need to charge it for a period from 3 to 7 days following the advice in
section 2.
2: Never use a boost or ‘electronic’ charger. Only ever use an old fashioned 2-3 amp
Trickle Charger, or a charger specifically designed to work with ‘Gel’ or ‘Glass
Mat’ batteries. The standard charger sold by the likes of Halfords will NOT charge this
battery correctly and may do serious damage to it.
hasse skrev:"Jeg var så dum at bruge startkabler på mit gel batteri.."
At startkabler og gel-batteri er en dårlig kombination vidste jeg ikke.
