SPS Motorsport
Re: SPS Motorsport
Indlægaf GuidoSPS » tors 26. mar 2020 11:38
Hey guys,
we have a special offer for You.
We sell our TD04-Turbokit for the MX-5/Miata NA, NB and NBFL for just 3499€.
On the stock 1.6L You get 220hp at the flywheel, on the stock 1.8L You get 250hp at the flywheel.
The kit contains:
Kraken cast iron manifold
Two-piece downpipe (first part made of cast iron, second part made of stainless steel)
Turbocharger incl. Matching connection accessories
Steelflex oil feed pipe
water pipe
High temperature oil return
Giselwerks Hardpipe boost pressure piping
efficient intercooler
Open air filter
SPS Motorsport 700CC Injectors (calibrated and tested)
Engine control unit with matching basemap
mounting material (incl. spark plugs BKR7EIX and modified washer fluid reservoir)
https://www.youtube.com/watch?v=v18XYMgpjmU&t=0s
https://sps-motorsportshop.com/shop/en/detail/index/sArticle/1834?number=TKIT-NA-16-TD-04-SLLK-MMS38998-SPECIAL
Best regards
Guido from SPS
GuidoSPS
Tilmeldt: ons 24. apr 2019 07:26
