Er bio-fuel skadeligt for Mx5?
Indlægaf hasse » ons 12. okt 2011 15:08
Fik et nyhedsbrev fra Moss-Europe om evt. skadelige effekter af bio-brænsel på motor, pumpe gummipakninger osv.
Det er på Classic cars men hvad med MX?
Her er en henvisning fra Moss.
http://fbhvc.co.uk/bio-fuels/
Indlægaf hasse » ons 12. okt 2011 15:55
Saksede lige fra moss' nyhedsbrev.
KUN reklamebrøl? Tvivler.
Is your Classic safe from the effects of Ethanol in fuel?
The EU has issued directives to increase the uptake of renewable fuels throughout Europe as part of the campaign to slow climate change. In addition, air quality concerns have been responsible for progressive reductions in sulphur in heavier fuels such as diesel. The net outcome of these EU directives is the inclusion of bio-Ethanol in petrol, and inclusion of components such as vegetable oils in diesel fuels, in addition to the reduction in sulphur content.
Scroll down to see what you can do to protect your car from Ethanol.
The Federation of British Historic Vehicle Clubs have been monitoring the effects of Ethanol in petrol since 2008, when they began to receive letters detailing problems. Early in 2009, members were asked to report their problems but very few did - however the numbers, and the levels of concern, increased in 2010-11.
A full report from the FBHVC and details following a consultation on Renewable Transport Fuel Obligations with the Department for Transport are available on their website... It makes very concerning reading for Classic Car owners.
The permitted Ethanol content in petrol is to rise from 5% to 10% in 2013.
Ethanol causes damage to engines that were not designed to withstand it... Those most likely to be affected are vehicles ten years old or older, carburettored vehicles and first generation direct spark ignition vehicles should not be fuelled on E10 (10% Ethanol) unless the manufacturer can state the vehicles are compatible with E10. The following problems may be experienced...
Corrosion caused when two dissimilar metals are in contact with an electrolyte, like Ethanol.
Rubber components like fuel hoses, carburettor seals and gaskets, and fuel pump seals may be hardened, dissolved or distorted by contact with Ethanol.
Ethanol holds water very readily and can expose fuel system components and steel gas tanks to rust.
Ethanol dissolves the lining of fibreglass fuel tanks. Eventually, fibreglass tanks dissolve until they fail, leaking fuel.
General corrosion, pitting and rust on metal parts.
The FBHVC would welcome a requirement for suppliers to ensure that fuel blended with Ethanol includes suitable anti-corrosion inhibitors to prevent corrosion in fuel systems of vehicles however; there is no legislation for this as yet.
So what can be done to save your Classic?
One option would be for fuel suppliers to incorporate additives direct at source to protect vehicles from these effects; however it should be remembered that our vehicles use a very small percentage of the total UK fuel sales and it may be difficult for retailers to commercially justify stocking such fuel even if the oil companies will distribute it. An immediate solution is available from Moss...
VSPE Power Plus
Lead replacement and octane booster with added benefit of Ethanol protection. Adds up to 2 octane numbers (20 points) to pump fuel, it prevents valve seat recession and combats the adverse effects of Ethanol in fuel. Also contains additives to prevent fuel system corrosion and anti-oxidants to improve fuel life. Recommended for all classic engines previously requiring leaded fuel, now running on unleaded fuel.
£7.46 ex VAT
£8.95 inc VAT
GGL4030X
VSPe
Special offer:
Click for 10 for the price of 9!
Lead replacement with Ethanol protection. Prevents valve seat recession and combats the adverse effects of Ethanol in fuel. Also contains additives to prevent fuel system corrosion and anti-oxidants to improve fuel life. Recommended for all classic engines previously requiring leaded fuel, now running on unleaded fuel, where an octane improver is not required.
£6.63 ex VAT
£7.96 inc VAT
GGL4031X
Indlægaf Niels » ons 12. okt 2011 16:04
2000 NB 1,8 Miracle - Supercharged by CCR
http://bilmagasinet.dk/article/19152
Niels
Tilmeldt: søn 14. jun 2009 22:13
Geografisk sted: KBH Ø
